how to duplicate comp?
Eric Viebe
on Jun 13, 2013 at 10:02:34 am
how can i duplicate a composition and change its properties without effecting the first one properties?
i allways get the same picture twice even if i duplicate the composition from the project window.i must be linked some how to the other comp.
Marco Conceicao
Re: how to duplicate comp?
on Jun 13, 2013 at 10:18:33 am
Hi Eric.
1) In the project panel select your composition, 1 left click.
2) Then, on windows, press CTRL+D. A perfect but independent copy should appear.
Is it what yoou need?
tielman dewaele
on Jun 13, 2013 at 11:41:14 am
Duplicate the precomp in the timeline. duplicate the precomp in the project window. rename it. change the properties there. and repclace it(alt+drop) over the duplicated precomp in the timeline.
Hope then makes sence.
T
MacPro/PC
Production Premum cs 5.5
FCP 7.0 studio
C4d R11,5 & R14
John Cuevas
on Jun 13, 2013 at 1:58:05 pm
Are you duplicating a precomp in the project window, because after duplicating it, a new version isn't automatically opened up in the timeline, you will still be working in the original until you open up the new duplicate(a mistake I make often)
There's a great script, True Comp Duplicator, that makes complete duplicates of a compe and it's precomps creating new links, you might want to check it out.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
