How to create a simple "water-wiggle" effect
Guilherme Maueler
on Jun 12, 2013 at 4:54:24 pm
hey guys!
i' was given a quick task today that seems simple, its animating this graphic element mimicking water invading the whole composition (i've included the animatic for it below), does anyone know of a way to make this without having to labouriously animate a mask path on a solid? Thats the only way i can think of doing this, and it would be kind of a pain :(
Here's what i'm talking about: http://184.172.153.221/~estud579/temp/water_animation.mov
John Cuevas
Re: How to create a simple "water-wiggle" effect
on Jun 12, 2013 at 5:38:54 pm
You could use some Ink or Water Splash footage and use that as a luma matte to reveal your image/layers below.
Creating Ink/Water transition can also be faked pretty easily using fractal noise(or a particle system), especially if the transition is fairly quick.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
