Importing H264 29.97 fps and using twixtor
Esther Casas
on Jun 11, 2013 at 2:49:10 pm
I am a bit new with twixtor and been reading a lot of forums here to find out what my problem is, but have not find it yet..
What I am trying to do: slowing down a clip (is an H264 shot at 29.92fps) from 100% to 25% speed (using some keyframes in between).
When I use twixtor Pro and export H264, the mp4 is looking very strange, I am adding a LINK here to show you what I mean (look at the guy with blue helmet and the snow around it, also snow in the whole frame moves strangely. It also happens at the end of the clip), ignore watermark...
I use warping: "inverse with smart blend" and left everything as it is by default (BG layer and FG1 settings etc.
Is this an artifact? Is just that twixtor works this way when tries to add frames when slowing down 4 times the speed? is a problem of working with H264? is the problem that was shot at 29.97fps?
Thanks in advance!!!
© 2018 All Rights Reserved
