How to change color of keyframe??
vipati hitesh
on Jun 10, 2013 at 4:22:59 pm
Hello All,
Here I have a silly question but if anyone help me, It will be very useful for me. Can I change color of keyframe? Normally, it's gray colored but can I change it's color??
E.G.- We can change color of mask by going in Preferences > Appearance > Cycle Mask Colors
For example, 1st keyframe is red colored, 2nd is yellow, 3rd is green etc.
Thanks in advance,
Vipati
John Cuevas
Re: How to change color of keyframe??
on Jun 10, 2013 at 4:46:40 pm
Can't be done: Feature Request
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Roland R. Kahlenberg
on Jun 11, 2013 at 12:10:12 pm
You can't change colors but you can index keyframes numerically - the Timeline's flyout menu allows you to set keyframe view to Index (or indices).
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE
vipati hitesh
on Jun 11, 2013 at 1:32:42 pm
Hello Roland,
Thank you for your reply. Please tell me how to index keyframes numerically?? What is Timeline's flyout menu??
Thanks again,
Vipati
on Jun 11, 2013 at 4:57:00 pm
Most, if not all, panels in AE have a menu at the top right. Mousedown on the menu icon to access features/properties for the specific panel.
HTH
RoRK
vipati hitesh
on Jun 11, 2013 at 5:11:16 pm
Hello Roland,
Sorry for asking same question again, but still I am not getting that menu.
As far as I understand you want to tell that I can give numbers to keyframes like 1,2,3 etc, Right??
Are you pointing out workspace menu, which is on top right corner with options All panel, animation, Effects, Minimal, Paint, Standard, Text etc.
Thanks again for giving time to my question.
on Jun 12, 2013 at 4:40:01 am
Every panel has a menu at its top right corner. It's very obvious if you look at the top right of each panel.
To select viewing of Keyframe Indices, this option is available in the Timeline Panel's flyout menu (also called wing menu and dropdown menu).
HTH
RoRK
vipati hitesh
on Jun 12, 2013 at 4:38:33 pm
Hey ! I got that menu. Thank you very much for your support. Now I can index keyframes numerically, it will be great if I can change color of keyframes but if it's not possible, Indexing keyframes is better.
V!pati
