Blinking frames after rendering
Hans Lettany
on Jun 7, 2013 at 9:42:52 am
I have a big problem here. In AEcs6, in a ram preview, but also in a final render, there show up kind of ghostflashes in the video from layers I already deleted. Even when I erased all cache memory, the ghostly frames are still there...
Anyone familiar with this problem?
thanks,
Hans.
Todd Kopriva
Re: Blinking frames after rendering
on Jun 7, 2013 at 3:29:42 pm
The folks on this thread will need more information to help, such as the information that you gave here:
http://forums.adobe.com/message/5387898
After Effects team blog
Hans Lettany
on Jun 7, 2013 at 3:38:08 pm
Hi all,
her some more info about the problem...
I use AE cs6, Latest update
12-core MacPro (2012)
24 GB memory
rendersettings prores4444.
used media: Apple XDCAM HD422 1080p
here the rendered exemple:
http://we.tl/W38b2MYjGK
thanks!
Jason Jantzen
on Jun 8, 2013 at 5:42:25 pm
that is really strange. I've seen flickering from plugins like 3d stroke and Element, but it doesn't look like you're using any of those, unless there's an instance of one somewhere else on the timeline. Have you tried purging the memory and cache? Do that, then try a RAM preview. If it previews correctly, there's likely an issue with whatever plugin you've used somewhere on the timeline.
Jason Jantzen
vimeo.com/jasonj
Hans Lettany
on Jun 9, 2013 at 7:14:57 am
Purged memory and din't use any plugins...
But I tried to replace the XDCAM-files with prores-renders from it and that helps for now...
thanks,
Hans.
Graham Jones
on Jun 29, 2013 at 11:38:28 pm
I'm having the same issue... AE CS6 11.0.2.11 on iMac quad i7 3.0 running Mac OS 10.7.5.
I'll have various frames missed in the render -- either an old cache frame seems to come back (even after caches deleted & purged), or one of the effects will be missed for a frame or two.
It's incredibly frustrating, and seems very intermittent. When it happens, I'll change one parameter and re-render, and I have a 50% chance of it happening the next time (if it does, it will be in a different spot).
Anyone else seeing this behavior, or have any ideas?
Gray.
