Interlacing progressive footage - how to really do it
Zachary Helton
on Jun 6, 2013 at 2:29:40 pm
I've done numerous web searches on how to interlace progressive footage for broadcast, but none of the responses I've seen actually say HOW to do so. There are usually vague references to Apple Shake, Quicktime 7, or Compressor being able to make the conversion, usually by simply exporting interlaced. This hasn't worked for me. The only time I got it to work before was on some 29.97fps video using After Effects, and the result was less than stellar.
What I have is this:
- Format: Apple ProRes 422
- Bitrate: Max.: Undefined / Average: 111 Mbps / Min.: Undefined
- Frame rate (fps): Max.: --- / Average: 59.940 / Min.: ---
- Encoding profile: Normal
- Width (Pixel number): 1280*720
- Pixel Aspect Ratio: 1:1
- Display Aspect Ratio: 16:9
- Interlacing: Undefined (this is what VideoSpec reports. It's progressive)
What I've got to end up with is 1920x1080, 59.94i.
Anybody know the fastest way to do this? I've got to convert 50 episodes and get them on the air.
I can use Shake, Compressor, FCP, After Effects, or Quicktime Pro 7, but I need pretty specific instructions. Anybody know how to do this?
John Cuevas
Re: Interlacing progressive footage - how to really do it
on Jun 6, 2013 at 4:15:26 pm
This shouldn't be much of a problem, looks like you are working on a MAC system and I'm not familiar with Compressor, but you should be able to bring your footage in as a source. Make sure that all the source settings are being interpreted correctly. Choose an output format of 1920x1080 59.94 and make sure that the fields are upper first. If compressor is like Media Encoder, you should have a preset to choose from and you'll be good to go.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Joseph W. Bourke
on Jun 6, 2013 at 4:20:35 pm
If this is going to broadcast, every station you deal with (unfortunately) is going to have a spec sheet with all the details you'll need to supply, and there's way more information than just
1920x1080, 59.94i. Generally, either the production manager, or the sales rep for the station can point you to the file. Here's a sample of Fox's requirements:
http://www.fox.com/_ugc/pdf/commercial_guidelines.pdf
Back to your question - interlaced footage requires Fields - depending on what you want to output, there are lots of variables which you have to be very aware of. If you have camera footage, what was it shot with? If it's already got fields, is it upper field first (1080 video is), or lower field? If not, you can just create an output template in AE which follows the specs the broadcaster gives you. Here's all the critical information on Outputting Separate Fields, which is another name for Interlacing, and may be what's confusing you:
http://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c11...
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
Zachary Helton
on Jun 7, 2013 at 2:25:10 am
Sorry, I shouldn't have said "footage" -- I have complete episodes that are 720p. There are no fields. I've tried exporting UFF in both After Effects and Compressor, but neither results in interlaced footage.
Tero Ahlfors
on Jun 7, 2013 at 4:02:07 am
If you want to render out interlaced from AE you need to choose the correct field from the Field Render pulldown menu in Render Settings. Your job would be really easy with Adobe Media Encoder.
Zachary Helton
on Jun 7, 2013 at 12:52:48 pm
Oh, I have Adobe Media Encoder, too; I've just never used it. Can I ask how to do so in Media Encoder?
John Cuevas
on Jun 7, 2013 at 1:31:56 pm
Absolutely, you can use ME. Without knowing your exact specs(so I can't comment on codec), you would follow these general steps. Take your 720p file and drop it into ME and chose the format(codec) you need to deliver to the station. There is probably a preset that will be close to what you need, but you may need to tweak. Click the preset button, click the video tab and there you will be able to specify 1080i 59.94
You can make a preset of your settings also, so once you are sure of it, you can just apply that to all your files at once.
Thinkck.com
Zachary Helton
on Jun 7, 2013 at 1:59:56 pm
Yes, I just did all of that, but it didn't produce an interlaced video.
John Cuevas
on Jun 7, 2013 at 2:21:17 pm
What are your exact settings, posting a screen capture here would be helpful, you can embed one using the third icon from the right in the reply dialogue.
Thinkck.com
Darby Edelen
on Jun 7, 2013 at 3:57:42 pm
When going from 59.94 progressive to 59.94 interlaced, what is your expectation? Mine is that you'll end up with a single frame across two fields. This means it will still look progressive. The only way in which it might be different than progressive is if the format you transcoded to includes some flags/metadata about interlacing and fields.
Darby Edelen
Darby Edelen
on Jun 8, 2013 at 7:29:00 am
Just realized that I made an incorrect statement in the previous post. You should be able to get from 59.94 frames per second to 59.94 fields per second and have each field represent a different instant in time (it should look "interlaced").
However, depending on the application you're using to create the interlaced file you may want to choose a 29.97 interlaced output rather than 59.94 interlaced. Both After Effects and Adobe Media Encoder work that way. You first select the 29.97 frame rate (not the field rate 59.94 as reported in 1080i 59.94) and then define whether the output should be progressive or interlaced.
Darby Edelen
Zachary Helton
on Jun 10, 2013 at 3:21:17 pm
Finally got what I wanted by stringing two AJA encoders together, going out analog and re-capturing digital interlaced. Problem is it takes up two work stations and I can't batch for a long overnight encoding slumber party, so I'd still love to figure out a more streamlined method.
Again, what I have is this:
And what I need to end up with is this:
wrapper: Quicktime
Video: ProRes 422 (HQ)
Resolution: 1920x1080
Fields: 59.94i
timecode: drop frame
Keith Slavin
on Jun 25, 2013 at 2:39:35 am
Hi Zachary,
This reply probably a bit late for your current problem (decoding, upscaling, interlacing and encoding), but just for your information, isovideo will soon releasing their file-based, GPU accelerated, motion-compensated standards conversion / transcoding server. Which can handle your current job fairly easily, quickly and with high quality.
If you still need help with this, you may contact me at keith@isovideo.com.
Keith Slavin
on Jun 25, 2013 at 4:07:08 am
Hi Zachary,
Paul Russell
on May 7, 2014 at 7:11:53 am
If the source was originated as progressive at 29.97 then you will end up with a repeated field within each interlaced frame, except that one field will be odd, one even, the picture content shall be the same essentially, you cannot alter the timebase of the capture as it were, just of the display pattern. In essence 29.97p footage will not have the smoothness of 59.94i, even if the re-encoded material is technically complient for interlaced timebase.
Think of it this way, if you had telecined film, the source film is only ever going to have the motion of 24p. Thats why film still looks different from video, even with a 59.94i telecine.
If your source footage was 59.94p (rare) then your conversion process would essentially chuck the even or odd lines away for the appropriate field and each of your two fields would have captured a slightly different moment, and so you would have the smoothness of motion expected from broadcast video, as well as the now correct scan pattern, but the key is in the source material. You cannot put in what wasn't captured.
Another handy tool for these kind of jobs is the free app JEC-deinterlacer, which is often more transparent in use than compressor etc. I'm not keen on the qt or adobe routes as they sometime try to enforce things like gamma correction or certain colour profiles, they can sork well but you really need to be up early and on the ball.
Ht Davis
on Feb 14, 2015 at 2:26:18 am
Unfortunately, doing this all at once is almost impossible on current hardware. You'd have to know some programming.
IF you know ame at all, you can have one tower set to do all the conversion with one hardware, and output to a folder on an external or a shared folder, and then on the other machine, have it "Watch" that folder in AME, and simply output to another separate location for the final step (watching a folder allows you to apply an automatic queuing and rendering with a set preset; so once the AME on the first machine finishes--if you use hardware encoders in ame it still works--with the first step, you can apply the second without even being there; and, yes it still requires two workstations).
From what I see:
You start out in 720p. So work with the frame size first. Upscale the frame size with everything else remaining the same. Now make any other adjustments to quality in your favorite editor, and (to do the same to each one you may have to script it) then have it export. I'm unfamiliar with FCP and compressor, but I know adobe has very little on the ball for this in premiere. You might be able to script it for AE, and have it queue up, then render them all out in ME.
With 50 videos, you'll want to just try one, then apply a gausian blur or the like to it and check a preview. Just a couple of minutes of it would do. Once you got that to your liking, take down the blur specifics and you should be able to create it as a filter for AME somewhere (eh, still haven't figured that one out). Do the watch folder thing and let it go.
Once you've done the frame size, you can play with the interlace. You need to set this to upper or lower field. I've found that lower-field is generally a better viewing on tv's. But you can do it however you want. It's a preference thing.
Ht Davis
on Aug 8, 2016 at 6:59:26 am
Fogive my last. Here's a better understanding of what you'll need to do.
First, double every frame. That's right, double the number of frames, and for every frame, you can do this using AE to copy a folder of images. Duplicate the folder. Place all the images into one folder, renaming one set as necessary. You should be able to render this to a file. Place in a new sequence set to the higher frame rate as you need, but keep the sequence in interlaced format (60i), both of the videos should be in progressive, on two separate tracks. Right click the one and tell it to display itself as the first field you need, do similar with the other file, but set it to the second field. Now you can output this video. You have twice the fields you need and twice the frames. Every field and frame is played twice. How do we undo this? Please If I have to explain everything to you... So far, we've only just begun. Nest this video in a proper sequence at 60i, speed it up 200%. Now it will blend every field to it's solid when you output, but display the fields properly staggered for playback. You'll be running them at 120hz, which is 60i'z playback framerate. If you have 60 progressive frames, you can roll them as 2interlaced frames, and they should look decent. It just takes time to run the files out. Don't count on any digital software to do this all for you. You have to render images first, double each one, then put them into two tracks, and designate each to play a single field, then dump it in another sequence and speed it up to 200%, add the audio at the end. The amount of time it takes should be the same. It will blend frames together if it has to... ;p Blending two of the same frame yields the SAME FRAME! It will take time to render the output as it processes each step, but if you start with a folder of images you can get a lot more done. You could resize the images to your desired viewing size fairly easy with a droplet. You could apply a sharpening action to one copy of the images so when they blend it becomes more natural-looking. It's all about how you want to make your workflow.
