revealing effect
Brian Murphy
revealing effect
on Jun 4, 2013 at 5:43:36 pm
I'm looking for a tutorial on how to have an object transition from one color to another. I was originally trying to use Card Dance as the transition but can't figure out how to make it sweep in a direction instead of all happening at once.
Here is an example of what i'm looking to do but instead of a morphing effect I just want the color of the object to change.
Tudor "Ted" Jelescu
Re: revealing effect
on Jun 4, 2013 at 7:10:17 pm
Card Wipe is better for transitions.
To just change the color you can try to key out that respective color and then use the keyed layer over the original with a Hue change and a wipe or if you can not use a keyer roto.
Tudor "Ted" Jelescu
Senior VFX Artist
