Can't make Motion Tracker 1 pixel wide
Colin Love
on May 31, 2013 at 1:55:07 pm
I want to track an object (horizontal line) in one axis only and hence I have made a tracker with feature size 1 pixel wide (100 tall) and search area 1 pixel wide (300 tall), but every time I start analyzing, the feature size, search area and centre revert to a default (feature 20x20, search 40x40). This doesn't happen if I make the feature size wider than 2 pixels, but then the tracker starts to wander sideways, which I don't want.
Sorry if this is a n00b question.
Roland R. Kahlenberg
Re: Can't make Motion Tracker 1 pixel wide
on Jun 1, 2013 at 1:04:22 pm
Your Search Area and Feature Area cannot be 1 pixel in size and certainly they can't be of the same value - you're way off here.
Track as per normal - with appropriate tracking options which include Search and Feature settings/size.
What you want should not dictate what you track. Rather, what you track should allow you to obtain what you want - sense make?
When you Apply the tracking data, you have the option to apply either X only, Y only OR X&Y tracking data. In your case, apply the X-only or X tracking data.
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE
© 2018 All Rights Reserved
