keylight with log-c workFlow
Erez Schwarzbaum
on May 27, 2013 at 7:42:43 pm
Hello ALL
I'm keying a log-c footage from arri alexa
I made it very good by applying a color lut but i need to send back a log-c.
that was my work Flow:
precomp of the green screen shot,
cleared all
than when i apply the trcmate on a untouched footage it dose not give me a good result and i have a green edges.
any ideas?
Angelo Lorenzo
Re: keylight with log-c workFlow
on May 27, 2013 at 9:58:07 pm
Keylight performs better with Rec 709/601 or P3 footage. Color correct first, apply keylight, and then use the resulting alpha channel on the original log-c footage. You'll find you'll usually get better results.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
Erez Schwarzbaum
on May 27, 2013 at 11:57:14 pm
tnx for reply.
i did color correct it first.
i did as you said already.
but when i use the alpha result on my log-c layer greens are coming back.
here example for before and after trc matte
© 2018 All Rights Reserved
