Issue with Polar Coordinates
Daniel Gómez
on May 27, 2013 at 1:51:50 am
Hello everyone!
I created an animation whose background includes:
- A brown solid
- Venetian Blinds effect, to create lines
- Polar Coordinates effect, to make a spiral effect with that lines
However, the result is not at all desired. I wonder if I can solve the problem indicated in blue in the following screenshot:
Or perhaps whether you can achieve the same spiral effect in another way.
Sorry for my english and thank you very much for your time :-)
John Cuevas
Re: Issue with Polar Coordinates
on May 27, 2013 at 1:46:24 pm
You could try using a shape layer(Polystar) and a twist effect, like this:
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Daniel Gómez
on May 28, 2013 at 10:45:42 am
It works awesome. Thanks a lot, John :-)
© 2018 All Rights Reserved
