How to stop slowly an expression?
Daniel Gómez
on May 27, 2013 at 1:41:51 am
Hello everyone!
I've created a composition with a small square inside. I want this square to rotate just 5 seconds, so I've made this expression to rotate the layer 72 degrees per second:
if (time <5) time*72 else 0
It works perfectly, but I wonder if there is any way to make the square stop slowly and not that abrupt.
Sorry for my english and thank you very much for your time :-)
Tero Ahlfors
Re: How to stop slowly an expression?
on May 27, 2013 at 7:04:05 am
Maybe you could link the expression to a slider control.
Daniel Gómez
on May 27, 2013 at 12:08:01 pm
Thank you very much for answering :-)
I tried to build the expression linking it to a slider control, but I'm not getting what I need. Not because After Effects; because of me, of course.
This is my project, right now: 6062_rotatingsquare.aep.zip
I want the square to be rotating regularly until it gets the second number five, where it's going to stop slowly, as if I'd used "Easy Ease In".
Hope I explained well. Thanks a lot again!
John Cuevas
on May 27, 2013 at 1:58:55 pm
Try using an easeOut expression on your rotation: easeOut(time, 0, 5, 0, 360)
I made a simple project using one, but did it over 20 seconds, because over 5 seconds, it seemed too fast: 6065_easeoutcs5.5.aep.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Daniel Gómez
on May 28, 2013 at 10:43:29 am
So helpful! Thank you very much. I appreciate your help :-)
