Any way to "reload" an imported AE project?
Ty DesEnfants
on May 22, 2013 at 3:09:37 am
From what I am reading there is no way to do this...but I am hopeful!
I have a master project that has dozens of other .aep's imported. When I make changes to any of the original .aep's they do not update in the master project. With changes to assets I can simply "reload" them to see instant changes...is there any way to do this with imported .aep's?
Dave LaRonde
Re: Any way to "reload" an imported AE project?
on May 22, 2013 at 3:58:42 am
Your fears are correct: once an AE project is imported into another project, it takes on a life of its own. If you make changes to the original project file, those changes DO NOT appear in the same project imported into another one. Likewise, if you alter an imported project, the changes do not appear in the original.
Dave LaRonde
Former Sr. Promotion Producer
John Cuevas
on May 22, 2013 at 12:02:33 pm
There is a third party app/script that does this, AE Project Sync. It has trial version, so you might want to check it out.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
