Adjustment layer effect won't motion track
Sean Offord
on May 20, 2013 at 8:57:51 am
Hi all,
I have an odd problem. I Am trying to do something seemingly quite simple - make a person's teeth grow into vampire fangs as he opens his mouth and moves towards the camera.
My null object layer is motion tracking perfectly and I am using liquify in an adjustment layer to distort the teeth. Then I am using the null object as the parent of the adjustment layer - but the distortion remains resolutely in the same place!
To double checkthat I was doing everthing right I added a text later and used the null object as its parent, and the text moved perfectly.
I'm very puzzled. I'm probably not doing something really obvious but I can't for the life of me work out what it is!!
Any help gratefully appreciated...
Cassius Marques
Re: Adjustment layer effect won't motion track
on May 20, 2013 at 8:23:40 pm
I think its because liquify is a compound effect and since it is applied to an adjustment layer it has no clue about it's layer's anchor point or any matters of positional data.
What you need is to add an expression in the distortion mesh offset and pickwip the tracked null's position.
Brent Taylor
on Aug 8, 2014 at 3:39:56 pm
Old thread, but I am having the same problem, so I thought I'd ask also.
Here is the tutorial I was using:
He does not have the problem Sean and I are having. No expression or anyting... it just works. But for me, just like Sean, the effect stays in the same place even though the adjustment layer follows the tracking null just fine.
Any ideas?
© 2018 All Rights Reserved
