3D Rotation problem in AE?
Varga Edmond
on May 16, 2013 at 6:40:39 pm
I am sure this has been posted a few times, believe me I was searching the forums but I still can't figure this out...:(
So, I have an image converted into a 3D layer, at the bottom of my composition window. As I try to rotate the object around the Y axis it starts facing at the bottom, and I don't get a nice rotation around this axis.
I know it has to do something with the Local and World axis buttons, but nothing changes when I switch between these. As I move the object back to the middle of the composition, the rotation works well...
How to rotate this in its place (bottom) nicely around the Y axes??
Ridley Walker
Re: 3D Rotation problem in AE?
on May 16, 2013 at 7:05:59 pm
Do you have a camera in the Composition? Are you certain you are viewing the Comp from the Active Camera View?
The above is normal behaviour. Do you want a view with no perspective?
See this thread:
Varga Edmond
on May 17, 2013 at 7:37:46 am
Thanks for your help!
What I needed was a perspective without perspective. As I set my focal distance to 200mm (as mentioned in the thread you gave me) I got the look I wanted.
Sincerly yours...
© 2018 All Rights Reserved
