After effect: Use anchor point for center of an effect expression
James Spadafora
on May 16, 2013 at 2:29:04 pm
Hello I have an animated object inside of a comp that has a anchor point that I would like to use as the center point for a radial blur.
the structure is: mapsComp -> myObject -> the anchor point.
What expression would grab this anchor point. I tried
thisLayer.layer(2).anchorPoint;
But that seems to not be working. Any ideas?
John Cuevas
Re: After effect: Use anchor point for center of an effect expression
on May 16, 2013 at 3:22:16 pm
Why can't you just pick whip to the anchor point?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
James Spadafora
on May 16, 2013 at 3:38:38 pm
Can I do that if I need the value from a nested comp?
Ridley Walker
on May 16, 2013 at 4:19:49 pm
You can open two Timeline panels, one for each and pick whip between them.
