whats the best size for 32'' vertical kiosk
yigit ersoy
on May 12, 2013 at 8:46:42 pm
Hello,i am making animation for kiosk display.This kiosk will be 32'' vertical.I made my animation 1920*1080 but i guess it wont show full screen.Please tell me the best size for full screen.Thanks
Todd Kopriva
Re: whats the best size for 32'' vertical kiosk
on May 13, 2013 at 12:01:41 am
Find out the pixel dimensions of the kiosk display and use that.
After Effects team blog
Mato Kokotic
on May 13, 2013 at 5:17:13 am
Not only that. In case that a kiosk is made with 32" LCD TV inside (which probably is), you need to plan that your animation should be delivered rotated by 90° (CW or CCW, depends on kiosk).
Dave LaRonde
on May 13, 2013 at 2:17:37 pm
...and also identify the kind of playback device that will be used.
For example, if for some reason the client insists on using a DVD player, it can NOT play back in HD.
Do you have delivery specifications for this project?
Dave LaRonde
Former Sr. Promotion Producer
Walter Soyka
on May 14, 2013 at 9:37:50 am
[Dave LaRonde] "For example, if for some reason the client insists on using a DVD player, it can NOT play back in HD."
And any interlaced video standard (SD or HD) feeding a portrait display turns the interlacing sideways. It's kind of freeing to be able to use thin horizontal lines with reckless abandon, but watch out for fine detail the other way!
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
