 | Problem with Mpeg (HDV) import to After Effects - Footage interperated wrong
on May 9, 2013 at 9:30:08 am |
Hello everyone,
I have been trying to use the dynamic link from Premiere CS6 into After Effects CS6 (replace with after effects composition). However, the footage is interpreted wrong; the frame rate is changed (0.024), there are only 2 frames of video, the video is a black screen and the resolution has been changed from 1440 x 1080 to 1440 x 810. The file size though once in After effects seems correct, but no video to back up the file size.
I have tried interpreting the footage but with no luck. It still persists with this problem.
Any ideas on where I'm going wrong? Hopefully you can see the image i have attached.
