Footage "flicker" with RAM preview and render
Martin Banks
on May 8, 2013 at 5:51:52 am
I have some footage to edit that was shot on a Canon 60D at 25fps.
I have used AE CS6 to put together the clips. There are about 14 precomps in the main composition.
When I RAM preview the playback, and also when I render out the video as an avi or H264, there appears to be a kind of flicker to the footage.
I wouldn't necessarily call it a flicker. There is a horizontal separation in the alignment of the footage as it pans. If that makes sense?
I'm on a Win7 64bit machine with 8GB RAM.
I'm guessing there is some kind of effect I can add to remove the flicker? It almost reminds me of exporting Canon footage from Premiere without using a progressive field order when exporting. Is there something in AE that will sort it?
Any help is grately appreciated.
Regards,
Martin.
Tudor "Ted" Jelescu
Re: Footage "flicker" with RAM preview and render
on May 8, 2013 at 8:02:55 am
Rolling Shutter - here's a couple of helpful links:
http://tv.adobe.com/watch/learn-after-effects-cs6/rolling-shutter-repair/
http://helpx.adobe.com/after-effects/using/rolling-shutter-repair.html
Tudor "Ted" Jelescu
Senior VFX Artist
Martin Banks
on May 8, 2013 at 11:39:18 pm
The Rolling Shutter Repair seems to have removed the "flicker", however it has darkened my clip somewhat. It was a woman filmed against a white background. Now the background looks like a dirty white or a grey. I have just tried adjust the levels on the clip, however it did nothing.
The clip uses the Multiply blending mode.
Is there a reason for this darkening? Can it be prevented? Is anyone able to suggest a how I can retain the clips original levels and still use the rolling shutter effect?
Martin.
