Sequence Layers with script
Dan Thomas
on May 8, 2013 at 4:12:09 am
Through jsx scripting, I would like to select some layers in a comp, and sequence them. Manually, this is done by clicking Animation -> Keyframe Assistant -> Sequence Layers. Is there a way to do this through jsx scripting? Thanks!
Ridley Walker
Re: Sequence Layers with script
on May 8, 2013 at 5:16:19 am
You might like to look at these 2 scripts:
http://aescripts.com/sortie/
http://aescripts.com/rift/
John Cuevas
on May 8, 2013 at 1:39:29 pm
Videocopilot had a free seequencer script that you can find in the project files of the 103. 3D Ball Dispersion tutorial.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Dan Thomas
on May 9, 2013 at 11:38:28 pm
Thanks John, from that I was able to do what I wanted. Here is what I ended up with for anyone else who needs it:
var frameRate = 30;
var maxDuration = 10;
var maxWidth = 760;
var maxHeight = 500;
var pixelAspect = 1;
theComp = app.project.items.addComp("out_test", maxWidth, maxHeight, pixelAspect, maxDuration, frameRate);
var comp_folder = findFolder (findFolder(app.project, "scenes"), "my_folder")
comp0 = findItem(comp_folder,"comp0")
comp1 = findItem(comp_folder,"comp1")
theComp.layers.add(comp0)
theComp.layers.add(comp1)
var duration = 0;
for (var i = 1; i var thisLayerLen = theComp.layer(i).outPoint
theComp.layer(i).startTime = duration
duration = duration + thisLayerLen
theComp.duration = duration
function findFolder (object, name){
var items = object.items
for (var i = 1; i < items.length; i++){
if ((items[i].name == name ) && (items[i] instanceof FolderItem)){
break
return items[i]
//Finds an item inside of a folder
function findItem( object, item){
for (var i = 1; i < items.length + 1; i++){
if (items[i].name == item){
return items[i]
