How do I make the tracker lines disapear for a bit
Joshua Green
on May 5, 2013 at 6:14:31 am
simply put, i just want to make the tracker points and lines invisible for a bit to see what I'm doing. I'm working on something and i need to be able to zoom in and see if the tracker is spot on or not but at some points there are so many tracker points in the way i can't see if it's right or not.
thank you in advance
Roland R. Kahlenberg
Re: How do I make the tracker lines disapear for a bit
on May 6, 2013 at 7:43:12 am
Look at settings in -
Prefs>Display>MotionPath
I set this to No Motion Path when tracking.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE
