Range selectors (stop speed variation?)
Chris law
on May 4, 2013 at 2:33:59 pm
Hi, im animating text with range selectors and Im just wondering, is there anyway to make it so no matter how many letters in a word, they all animate at the same a speed, because theres a variation when u have a short word and then a longer one after.
Kevin Camp
Re: Range selectors (stop speed variation?)
on May 6, 2013 at 4:30:40 pm
you could do this with expressions....
first, in the range selector>advanced settings set the units to 'index'.
then select the end value and choose animation>add expression and add this expression to the expression field:
this will set the end value to be the number of characters in the layer's source text no matter what you type.
now, add this expression to the offset property:
rate = 5; // characters per second
(time - inPoint) * rate
this expression simply takes the current time (in seconds), adjusts for the layer's in-point and multiplies that by a rate that you can set.
you can adjust the layer's in-point to adjust the start time of the effect-on. if for some reason that won't work for you, there are other ways to set the timing.
Kevin Camp
Senior Designer
© 2018 All Rights Reserved
