Audio Sync AE after exporting from PP
André Raposo
on May 3, 2013 at 9:21:38 am
Good morning,
This is my first post here, but I've been following this forum for a long time. This is my first (Videoclip) "big" project and I am having a problem although I always used this same workflow for the other projects.
I did all the editing in Premiere Pro CS5.5 and after I finished it copy paste de sequence into AE CS5.5. The problem is, in AE after export (.mov, Jpeg codec) the music is not correctly syncronized, despite the begining and the end match with the lips movement there is some kinf of a strange delay e he sound. This is what I've tried:
1.Export directly in Premiere Pro: Correct Sync
2.Export in AE with .aiff .wav and .mp3: Bad Sync
3.Export in AE with no effects at all: Bad Sync
Can it be something in the footage frame rate diference between AE and Premiere? Or the sound rate?
It's the first time this happens, it's very strange...
Aby suggestions would be helpfull! Thank you!
Best regards,
André Raposo - Portugal
© 2018 All Rights Reserved
