blender to AE jsx script - Major challenges
Josh Brine
on Apr 26, 2013 at 10:50:09 pm
blender 2.64, After effects cs5.5
So i have a scene with a windows tablet model spinning, with a camera dolly out and back in again.
I Rendered the sequence out.
I then use the jsx exporter to bring the camera and various null objects into After effects so i can add a screen to the tablet in AE
1. run the script, create the composition
2. import the blender render, interpret footage, set correct aspect ratio, FPS etc.
3. add the render to the composition, put in at bottom of layer stack
4. create new solid, make 3d, parent to Null, reset position, rotation, set correct scale, orient to match perspective.
This all works fine.
Once i play the animation, the plane does not continue to sit where it should, it is almost as if i have the wrong orientation, and yet the position in 3d space is accurate, and the orientation matches in one perspective, but as the camera and object move it changes, almost like a drifting point camera track might do.
I cannot see where i have gone wrong.
is it the versions of blender/AE?
Is it a setting i have missed?
are there certain animations that do not work?
It feels like it could be either lens distortion or some issue with the lens/camera difference between blender and After effects.
its so close to working, the thing i cant seem to find a solution too is this perspective shift, short of key framing it by hand i have yet to find a solution.
please any ideas would be much appreciated
© 2018 All Rights Reserved
