Current Time Indicator (CTI) Sync between Comps
Dan Peck
on Apr 22, 2013 at 4:56:55 pm
Is there a way to sync the Current Time Indicator (CTI) between multiple comps and see those comps refresh at the same time in the comp viewers?
Ie I have a compA at frame 200 and CompB at 200 then when I step through the time line the frame numbers match and both refresh on the comp viewers.
Any ideas?
John Cuevas
Re: Current Time Indicator (CTI) Sync between Comps
on Apr 22, 2013 at 5:17:13 pm
Edit > General > "Synchronize Time of All Related Items"
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Dan Peck
on Apr 22, 2013 at 8:34:29 pm
Thanks John, but this doesn't work as the comps are seperate and not precomps.
John Cuevas
on Apr 23, 2013 at 2:43:06 am
If the comps have no relationship than moving in one would have no effect on the other. I suppose you could create a blank precomp, place it into each Final comp. Open up and lock both comp windows, open the precomp and move through that and when you moved around the 2 downstream comps would move with the same time code.
Not sure if that work around will help you out or not.
Thinkck.com
Dan Peck
on Apr 23, 2013 at 8:42:17 am
Thanks John, this was something I'd hoped to avoid. I thought this function would be inherant to AE.
Sounds like a feature request to me.
Walter Soyka
on Apr 23, 2013 at 9:08:43 pm
[Dan Peck] "Thanks John, this was something I'd hoped to avoid."
You can turn the visibility off, or make it a guide layer (or both) to make sure it doesn't render when you output.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
