open exr in AE
Ali Quintana
open exr in AE
on Apr 16, 2013 at 5:36:45 pm
Can open exr files use material ID and Object ID.
I am rendering out of 3d Max.
Todd Kopriva
Re: open exr in AE
on Apr 16, 2013 at 6:52:48 pm
Yes.
See After Effects Help.
After Effects team blog
Ali Quintana
Re: open exr in AE
on Apr 17, 2013 at 10:49:32 pm
Thank you, very helpfull....
I got as far as opening the exr in AE and even the reflection layer is fixed...
How ever what ever I do I cant see to get the Obj id not Matr Id working....
I am used to RPF and they are easy to get the IDs on seperate layers... so to get object or materials on seperate layers for induvidual color correction...
Is there any one that can help?????? pleas!!! Cant get the ID to work on my exr files in AE
Todd Kopriva
Re: open exr in AE
on Apr 17, 2013 at 11:08:58 pm
Are you using the IDentifier effect that is mentioned on the page that I linked to?
Ali Quintana
Re: open exr in AE
on Apr 18, 2013 at 4:55:30 pm
Yes, I am trying to use the identifier, but it says in the effects pannel in the identifyer "NO OBJ ID availanle".
Of course I did extract the Obj ID first, the layer turns into colors, like pbjects all get a color.... then applied the identifyer.
cant seem to get it to work...
I would like to eventually get layers with different object, Is that possible at all??
