Losing hard drive space
Daniel Wiltshire
on Apr 14, 2013 at 2:40:33 am
I recently started a After effects project and i had around 100GB of space of my Computer then when i checked after i was finished i had only 30GB space. I was just wondering how this happened and how i can fix it?
Regards
Daniel Wiltshire
John Cuevas
Re: Losing hard drive space
on Apr 14, 2013 at 3:02:34 am
The first thing I would check is your Edit > Media & Disk Cache and check and see how much space you have allowed to be used. You can also empty the caches from here too.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Daniel Wiltshire
on Apr 14, 2013 at 4:01:26 am
Yes this is what the issue was
Thank you very much
