 | plexus: freeze line connections?
on Apr 10, 2013 at 6:18:03 pm |
hi all,
I'm curious if there is a a way to "freeze" plexus lines once you've found a nice configuration;
in other words, make them stop looking for new connections, even when animated with noise, etc
thanks,
LML
 | Re: plexus: freeze line connections? on Apr 19, 2013 at 3:02:11 am |
I figured it out, in case anyone else had a similar question:
go to the lines renderer settings, down at the bottom, under "calc lines distance", and instead of all frames, select one frame (or time interval--kind of a cool effect)
works great on my pc (not on my mac for some odd reason)
ML
