simulating "freeze transform" feature of 3D apps in AE?
manojit ghose
on Apr 10, 2013 at 12:37:28 am
is there a possibility to make the PSR of a null to have (pseudo)zero values after i move/scale/rotate to desirable values.
essentially what i am seeking is to be able to simulate the "freeze transform" feature in 3d applications.
thanks
m.
MG
Walter Soyka
Re: simulating "freeze transform" feature of 3D apps in AE?
on Apr 10, 2013 at 12:51:41 am
You could add a new null. Hold shift while parenting the new null to the old null (this is new in Ae CS6) -- this will copy the transforms from the original null to the new null. (Pre-CS6, copy and paste PSR.)
Now unparent the new null, then parent the old null to the new null.
Your original null will now have zeroed-out transforms because they are measured locally relative to the new null, which had matching transforms in world space.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Paul Stevenson
on Apr 10, 2013 at 10:48:37 am
That's good to know Walter.
manojit ghose
on Apr 10, 2013 at 3:09:52 pm
hi walter,
thanks for your reply.
jusnt in case someone else needs this... i found a (sub)tool- "Zero" in the Duik toolset, which does what i wanted to the position in oneclick.
thanks
m.
MG
Walter Soyka
on Apr 10, 2013 at 3:11:08 pm
That's cool. Thanks for posting back with the solution -- it's very helpful!
Walter Soyka
