Will This Set-up Build Work well for AF and PR?
Heath Bursley
on Apr 9, 2013 at 10:02:45 pm
CPU: AMD FX-6100 3.3GHz 6-Core Processor
CPU Cooler: Arctic Cooling ACALP64-GT 25.6 CFM CPU Cooler
Motherboard: ASRock 970DE3/U3S3 ATX AM3+ Motherboard
Memory: Crucial Ballistix 12GB (3 x 4GB) DDR3-1866 Memory
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Storage: A-Data Premier Pro SP600 32GB 2.5" Solid State
Video Card: Zotac GeForce GT 640 2GB Video Card
Case: Logisys CS206BK ATX Mid Tower Case
Power Supply: 480W
On A Budget - and Only Doing 3-6 min videos....
Will this run alright
Walter Soyka
Re: Will This Set-up Build Work well for AF and PR?
on Apr 10, 2013 at 12:43:57 am
I'd consider dropping the 32 GB SSD for now -- that's pretty small -- and replacing it with a second mechanical hard drive so you can have a bit more capacity. Use the first drive for your system and apps, and use the second drive for media.
I think you'll be a lot happier with 24 GB of RAM than with 12 GB. If you want to really exploit your 6-core processor via multiprocessing in Ae, you'll need more RAM.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Heath Bursley
on Apr 10, 2013 at 10:44:22 am
Memory: G.Skill Ripjaws X Series 24GB (3 x 8GB) DDR3-1866 Memory
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Disk
Case: Logisys CS206BK ATX Mid Tower Case w/480W Power Supply
Total: $675.05
Old Total $492.98
upping the ram and ssd for 175, or is it better to get a high gpu?
Walter Soyka
on Apr 10, 2013 at 12:48:59 pm
[Heath Bursley] "pping the ram and ssd for 175, or is it better to get a high gpu?"
I say more RAM and storage now, better GPU later. Put the OS on the SSD and use the 1 TB mechanical HDD for media & project files.
The bottleneck in this machine will always be the AMD CPU. The FX-6100 offers good value (performance/price), but relatively poor absolute performance.
Walter Soyka
