24fps to 29.97fps via AE vs Adobe Media Encoder
Anhtu Vu
on Apr 6, 2013 at 4:20:09 pm
I need to convert an animation mov from 24 fps (yes 24 and not 23.976) to 29.97 fps for broadcast.
I was wondering if there are any advantages in doing it in AE vs Adobe Media Encoder. The Media Encoder method is way faster. Anyways here's my workflow:
In AE:
1- Import 24p footage and Interpret Footage as 23.976 fps
2- Add comp to render cue and set Field Render to Upper Fields First and set 3:2 pull Down Pattern to WWSSW
3- Sound is Done in ProTools
4- Merge sound and pic back using QT Pro then output as self contained
or
In Media Encoder:
1- Import file and set output to the right Frame rate...that's it
Will both method yielded a proper 29.97 file ??? Thanks
Todd Kopriva
Re: 24fps to 29.97fps via AE vs Adobe Media Encoder
on Apr 7, 2013 at 6:55:49 am
You have much more sophisticated frame blending in After Effects, which is important when changing frame rates.
details:
http://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906...
After Effects team blog
