World Position Pass ?
Bernhard Rieder
on Apr 1, 2013 at 6:32:08 pm
Hello,
is it possible to use a World Position Pass without the use of any plugins inside After Effects ?
If so, any tutorials that shows and explains how it works ?
Thank you very much !
Darby Edelen
Re: World Position Pass ?
on Apr 2, 2013 at 5:24:41 am
[Bernhard Rieder] "is it possible to use a World Position Pass without the use of any plugins inside After Effects ?"
Use it to do what exactly? The pass itself is just image data. It's what you do with that image data that can make things interesting.
That said I'm not aware of any AE plug-ins that would use a world position pass and there aren't many good reasons I can think of to try and use one in vanilla AE. You could use it the same way you'd use any other image. Maybe you'd be able to create some interesting mattes with it?
Is there something specific you're hoping to do?
Darby Edelen
Walter Soyka
on Apr 2, 2013 at 3:48:03 pm
Check out Pixel Cloud [link].
It's a third-party plug-in, not a native solution, but it's the first thing I'd go to for using a position pass in Ae.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Bernhard Rieder
on Apr 2, 2013 at 6:40:43 pm
yes... the wpp can help you for masking and positioning compositing elements to a specific world space coordinate.
it's used in comping software packages like nuke or fusion.
just have not seen it yet in AE - without using any plugins.
Andrew K. just brought out his plugin and he is using the wpp as well.
But my question was: How to use it inside AE without any 3rd party plugin ?
thx a lot
Walter Soyka
on Apr 2, 2013 at 7:41:05 pm
[Bernhard Rieder] "But my question was: How to use it inside AE without any 3rd party plugin ?"
To do what specifically?
Unlike Nuke, Ae doesn't have a native concept of point clouds. That's why you need the plugin to do anything useful with a position pass.
Walter Soyka
Bernhard Rieder
on Apr 2, 2013 at 9:12:48 pm
I see.. I guess that's the issue with AE, that it doesn't really support the true point cloud data.
But thx for posting the link to the plugin, looks very promising !
Appreciate that !
Darby Edelen
on Apr 2, 2013 at 11:11:58 pm
[Bernhard Rieder] "just have not seen it yet in AE - without using any plugins."
Again, it's just an image. AE does natively support images :)
There isn't anything super special about a position pass, the value is in what you or an application does with the data in the pass.
AE can't do anything fancy with the data in the position pass out of the box, but with plug-ins or some color correction or even expressions you can still use the data to some effect.
Perhaps if you described exactly what you wanted to achieve with the position pass we could help.
Darby Edelen
Christopher Vranos
on Apr 12, 2013 at 2:10:27 am
Yes! I actually have software specifically dedicated to this, that will soon be an After Effects plug-in.
Check out ChrisVranos.com for all the videos, or skip right to this one to get right to it.
Unfortunately the plug-in isn't readily available yet, still working on it.
Tom Daigon
on Apr 12, 2013 at 3:48:08 am
Very cool idea.
Tom Daigon
PrP / After Effects Editor
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid
