Particle World Question
Lenny Vaknine
on Mar 29, 2013 at 8:43:33 pm
Hey guys this may seem like a noob question but I am using particle world: stars and I would like to add an x on every star to make it more robust, how can I achieve this?
John Cuevas
Re: Particle World Question
on Mar 30, 2013 at 12:57:18 am
You need to make custom particles to do that. So create a comp 200x200 and create your star with an X. Bring that into your main comp and turn off it's eyeball. Create a solid, add Particle World and change the particle type to textured square. Open the texture Layer and choose your precomp with the star.
This probably isn't exactly the custom star you have in mind, but here's an example project illustrating the concept: 5745_customparticlescs5.aep.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
