Mask Doesn't work when Time warp is on!
Christopher Fodde
on Mar 28, 2013 at 5:01:49 pm
I'm making a clip where the screen goes black and white and then I use a mask to highlight a person. The problem is there is a part where I have to use time warp but then the mask doesn't work which makes the clip useless.
Cassius Marques
Re: Mask Doesn't work when Time warp is on!
on Mar 28, 2013 at 5:37:40 pm
Some effects render prior and above everything else, You'll have to precompose the layer with the mask, and apply timewarp to that precomp.
Dave LaRonde
Yup, that's right!
on Mar 28, 2013 at 6:02:51 pm
Do your Time Warp work first, prerender and THEN mask the resulting file. Otherwise it will lead to headaches, as you've experienced.
Dave LaRonde
Former Sr. Promotion Producer
Tudor "Ted" Jelescu
on Mar 28, 2013 at 7:48:47 pm
My suggestion is to apply all other mask/effects before the Time Warp. Precomp and then apply the TW.
Tudor "Ted" Jelescu
Senior VFX Artist
