Stroking Shape Layers individually then merging
Moog Gravett
on Mar 22, 2013 at 11:01:28 am
Hello folks,
Is there any way I can take two shape layers, which are animated individually, but have any modifiers (i.e. strokes) merge as they cross?
For example, a bit of text which is all spread out ' T---E---X---T' each letter has a stroke. then as they come together 'TEXT' the stroke layers (let's assume I'll use a number of strokes) merge to outline the word?
Cheers
Moog
Freelance | Video Editor | After Effects | Camerawork
http://www.Peculiana.com
Dave LaRonde
Re: Stroking Shape Layers individually then merging
on Mar 22, 2013 at 3:01:40 pm
Why not do this with text layers?
Dave LaRonde
Former Sr. Promotion Producer
Moog Gravett
on Mar 22, 2013 at 3:08:47 pm
Hi Dave,
I couldn't get it to work that way either and thought it might be easier with shape objects. But if thers a way round with text layers and masked solids etc... I could make that work.
Got any tips?
M
Dave LaRonde
on Mar 22, 2013 at 3:52:42 pm
You can make text layers with transparent fill and STROKE ONLY.
I'd start by animating a text layer with fill & stroke do do what you want, and use it as a template. Then duplicate it and change the character settings to stroke only on one layer, and fill only on the other.
If I read you right, it ought to do the trick for you.
Dave LaRonde
Moog Gravett
on Mar 22, 2013 at 4:54:02 pm
Thanks, I'll have a play with that.
