Slow down frame rate of effect while maintaining composition frame rate
Adad Warda
on Mar 19, 2013 at 1:25:52 pm
Hi I am trying to apply the brush strokes effect to 24p video in after effects, however the brush strokes change their pattern every frame and I would like to slow it down. I could use the time posterize effect or slow the frame rate of the composition. However, I would like the video to play back at 24p while the brush strokes effect changes form every 3 or 4 frames. But I can't figure it out - perhaps expressions or some other way?
Any help is appreciated!
Adad
Todd Kopriva
Re: Slow down frame rate of effect while maintaining composition frame rate
on Mar 20, 2013 at 10:01:10 pm
I'd precompose the part that I wanted at the lower frame rate, change the frame rate for that nested composition, and leave the containing composition at the higher frame rate.
After Effects team blog
