1 minute Rotoscoped footage taking 48 hours to render?
Johnny Opamo
on Mar 18, 2013 at 7:10:27 pm
I'm making a music video for college in which the talent is walking with a trail effect behind him. To achieve this I spent a while rotoscoping 2000+ frames and now want to render it. I've tried rendering the file in various different formats and on different computers with bigger memory and still it takes 48 hours to render.
The render time doesn't go down. It just slowly goes up. I've spent many days and nights leaving my laptop on and it just pauses and increases the time.
Any help on alternatives to rendering the footage or if I can export the file to another program or anything would be most appreciated.
Thank you
Darby Edelen
Re: 1 minute Rotoscoped footage taking 48 hours to render?
on Mar 18, 2013 at 7:56:17 pm
Can you give a more detailed description of what's going on in the comp you're rendering? Are you using any effects? What is the source footage? What resolution is the source footage and composition? Are there any footage items other than the rotoscoped sequence?
Darby Edelen
Johnny Opamo
on Mar 18, 2013 at 8:29:48 pm
It's just a minute long sequence in black and white with blur and echo effects on the middle layer and rotoscope on the top layer and the original video on the bottom layer. The video is in 1080p.
Darby Edelen
on Mar 18, 2013 at 8:40:49 pm
[Johnny Opamo] "echo effects"
Tell me more :)
If you're actually using more than one echo effect that could definitely be causing trouble.
Darby Edelen
John Cuevas
on Mar 18, 2013 at 8:49:16 pm
I'd render out my rotoscope first(prerender) then bring that in for the echo treatment...
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Johnny Opamo
on Mar 18, 2013 at 11:01:29 pm
I've just tried rendering the rotoscope layer alone using the alpha channel but still it's taking way too long for a minutes worth of footage. It says "rotoscope propogating" then counts from 1 to [which ever frame its on] so by the end it'll have to count up from 1 to 1500. It's taking around 30mins to an hour to render ONE frame. One out of 1500, this is ridiculous.
Is there any other solutions? Any other way I can render it out? I have important deadlines to meet and will fail if I don't get this done.
Tom Daigon
on Mar 18, 2013 at 11:09:54 pm
This is an intriguing mystery. If you can make this 1 minute clip downloadable I will see how it does on my system, as a point of comparison to help figure out whats up.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid
Johnny Opamo
on Mar 18, 2013 at 11:18:43 pm
Here's a download to the AE project file - this is the full 2 minute version.
I tried to split it up into 2 1 minute clips so it takes less time to render but it's not working.
http://www.mediafire.com/?4kf51ujbs4ut4wb
Tom Daigon
on Mar 18, 2013 at 11:22:04 pm
That file is JUST the AE project. You need to send the project AND the media. :D
Tom Daigon
HP Z820 Dual 2687
64GB ram
Johnny Opamo
on Mar 18, 2013 at 11:32:39 pm
I'm sending that through here directly, it's just taking a while :/
Tom Daigon
on Mar 18, 2013 at 11:33:40 pm
OK.
Tom Daigon
HP Z820 Dual 2687
64GB ram
Tero Ahlfors
on Mar 19, 2013 at 4:42:59 am
[Johnny Opamo] ". It says "rotoscope propogating""
So you're using rotobrush then? Freeze the rotobrush and then maybe read the manual for that.
