Fill a 3D shape layer with an image and keep the image 3D
Guy Borghouts
on Mar 12, 2013 at 4:12:01 pm
Hi, I've been lurking and learning form this forum since I'm using AE for a couple of weeks.
Today I couldn't find a solution how to use an extruded 3D shape layer which would have a fill on the front from an image file.
The solution I found was to make a comp of the 3D shape layer and add the image in 3D just in front of it.
Then go the material options to set the 'Appears in reflections' to 'Only'.
Make sure the shape layer has a Reflection Intensity of 100%.
This way you can use the comp in 3D, while the image follows the perspective changes of the 3D shape layer. (parenting didn't work as the perspective got messed up)
So maybe someone else has a use for this technique as well. (or maybe someone else has a more obvious one).
Roland R. Kahlenberg
Re: Fill a 3D shape layer with an image and keep the image 3D
on Mar 13, 2013 at 4:46:13 am
If you're working with the Classic 3D Renderer, you can
1) Shift+Parent the Texture Layer to the Shape Layer
2) Ensure the Shape Layer is above the Texture Layer
3) Apply the Alpha Matte track matte to the Texture Layer
4) Then tweak the z-position of either layer such that the Texture Layer is in front of the Shape Layer.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7)
Guy Borghouts
on Mar 13, 2013 at 7:29:23 am
Yes, that was for the classic 3D renderer the best solution I found, thanks! The solution I needed in the end was for ray-traced rendering.
on Mar 13, 2013 at 3:57:01 pm
See if this helps - http://blog.rampantdesigntools.com/2012/05/22/textured-3d-extrusions-in-aft.../
Cheers
RoRK
Guy Borghouts
on Mar 13, 2013 at 6:39:59 pm
That's a good too. Looks very complete. Must do some editing and so on to see if my technique holds up under all circumstances.
