Transparent backgrounds?
Anthony James
on Mar 12, 2013 at 1:14:38 am
I know, I know, it's an easy task on AAE, but I can't seem to get it to work.
I followed the instructions on the second post of this thread: http://forums.creativecow.net/thread/202/892220
However, I cannot get it to do what I want it to do. All I want is to be able to create an audio waveform (already know how to do that) with a transparent background and be able to move it to Sony Vegas to edit it from there.
I was able to do this some time ago, but I can't figure out how to do it again. Whenever I move the rendered video to Vegas, it does NOT have a transparent background, instead having solid black.
Any help would be very much appreciated. Thanks!
John Cuevas
Re: Transparent backgrounds?
on Mar 12, 2013 at 2:14:10 am
What codec did you select when you render? I don't know Vegas, but do you have to set anything in that program to let it know you want to use an alpha channel?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Todd Kopriva
on Mar 12, 2013 at 2:57:02 am
As Johnny indicates, we need to know what your render settings and output module settings are. The best way to tell us is with screenshots of your render settings and output module settings (from the dialog boxes).
After Effects team blog
Vishesh Arora
on Mar 12, 2013 at 8:55:24 pm
Anthony
As everyone said, You need to export with RGB + Alpha to have transparency.
Check this article:
Render with Alpha(Transparency)
To import Footage containing Alpha Channel, Check this:
Steps
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
2011 3D Demo Reel:
