Animating text with sliders
Josh Smith
on Mar 11, 2013 at 1:51:18 pm
Hi everyone,
I would like my text layer to count up from 0 to 1,800,000 over the course of 60 seconds. I have tried to use a slider control, but I can only get it to go up to 1,000,000. How can I fix this?
Also, how do I only animate part of the text? So, for example, I have it saying: "Time elapsed: 0 seconds", and I would like it to animate just where the "0" is, from 0 to 60, and the rest stays the same.
Also, how can I add commas into the animated numbers? So that I get 1,800,000 and not 1800000?
Thanks for your help!
Josh.
Joseph W. Bourke
Re: Animating text with sliders
on Mar 11, 2013 at 2:05:52 pm
I think that, in your case, Expressions are going to fill the bill. Here's a link to the expression, and a way to get numbers over a million:
http://www.videocopilot.net/forum/viewtopic.php?f=5&t=78872
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
John Cuevas
on Mar 11, 2013 at 2:22:00 pm
If instead of using a slider, you use Effects > Expression Controls > Angle Control, you can go over 1,000,000. I have no idea why angle control can do this and slider can't, but it's a good little work around.
So use the counter link that Mr. Bourke provided, but in the directions where it says use a slider, just change that to angle control.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Todd Kopriva
on Mar 12, 2013 at 12:33:52 am
There's no good reason for the slider control value to max out at 1,000,000. I'll see if I can fix that.
After Effects team blog
