Composition size
Kristin Henry
Composition size
on Mar 8, 2013 at 2:57:50 am
I'm working on an installation that uses after effects to project animations onto a print in a gallery and finding that configuring the composition size to the size of the canvas print is making AE run really REALLY slowly. The print is 12000x18000 pixels @300 ppi (40in x 60in). I guess it just occurred to me that I need to find out if composition size should be configured to the size at which I would like the image to be projected or some scaled down ratio thereof. Will I lose a ton of resolution (using a high resolution projector) if I scale my image down a bit? Help?!
Kris
Angelo Lorenzo
Re: Composition size
on Mar 8, 2013 at 4:22:32 am
So you're working on a video that will be projected? or a comp that will eventually be printed?
If it is the former, then your approach is flawed. You should find out the video resolution of your projector (1080HD, 720HD, standard def) and then use black solids to mask portions of your frame if needed to match the 2:3 aspect ratio. Far more manageable since you'll be limited by the projector.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter
Kristin Henry
on Mar 8, 2013 at 4:32:19 pm
It's the former but this is all helpful. Thank you!
Dave LaRonde
on Mar 8, 2013 at 4:30:25 pm
You should set the dimensions of your AE comps to those of the projection device. Anything more is overkill.
Dave LaRonde
Former Sr. Promotion Producer
