Handheld camera simulation
Daniel Waldron
on Mar 7, 2013 at 8:14:35 pm
I am slowly pushing in on text with a camera in my composition. I want to give it a kind of random, handheld feel. Not too shaky, but definitely slight variances in the rotation and point of interest to give it a handheld, steadycam look.
I've been messing with a wiggle expression and it looks ok, but I was curious if anyone else had other suggestions.
Kevin Camp
Re: Handheld camera simulation
on Mar 7, 2013 at 8:19:10 pm
if your text is 3d and you are using a 3d camera for the move, try adding wiggle to both the camera point of interest and the camera's position.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Daniel Waldron
on Mar 7, 2013 at 8:22:21 pm
Good suggestion. I was just going to try that actually. I have the wiggle expression on the position, but I think adding it to the point of interest will really help.
Tyler Wiethorn
on Mar 7, 2013 at 8:42:27 pm
Think about what real camera shake looks like. Wiggle position, point of interest, and rotation.
Conrad Olson
on Mar 7, 2013 at 9:31:03 pm
To get really realistic movement you can always shoot something with a handheld camera. Camera track that footage and then apply that camera track data to the camera in your scene.
conradolson.com
Daniel Waldron
on Mar 7, 2013 at 9:45:47 pm
All great ideas. Thanks for all your input!
Vishesh Arora
on Mar 7, 2013 at 10:34:16 pm
Daniel
Check this tutorial on How to control wiggle expression:
http://allbetsareoff.com/tutorials/keep-your-wiggle-under-control/
It will help you to experiment with amplitude and frequency if wiggle without entering the values again and again.
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
2011 3D Demo Reel:
Darby Edelen
on Mar 8, 2013 at 1:20:24 am
Another good thing to modify if you are using a wiggle() expression are the octaves.
The first two properties supplied to wiggle (frequency and amplitude) are required for the expression to work, the rest of them are optional. If you supply a value for the 3rd property in the wiggle you can increase the number of octaves from the default:
wiggle(1, 10, 3);
The above, for example, will wiggle with a frequency of 1 Hz, an amplitude of 10 but with 3 octaves. This is similar to the "Complexity" of the Fractal Noise effect. It will preserve the overall effect of the wiggle but create additional "sub-wiggles" that add detail.
Here's an image of a wiggle() with 1 octave:
And here's a wiggle() with 3 octaves:
Note that both curves follow the same basic path, but the one with 3 octaves has more "sub-wiggles." If you want to reduce or increase the effect that these additional octaves have you can add a 4th property to wiggle():
wiggle(1, 10, 3, 0.2);
The default value is 0.5. A value of 0.2 would reduce the effect that the additional octaves have on the total wiggle.
Darby Edelen
