Keylight, masks and layer style question
Joe Stas
on Mar 3, 2013 at 12:40:30 pm
Hi
This might just be a something simple I'm overlooking but my brain can't understand why this is happening.
I have some green screen footage, I draw a garbage matt on it and then apply keylight. Everything keys out fine as the green is very consistent.
I then add a stroke to the footage as a layer style and it becomes visible where I have drawn in the mask as well as around the person in the footage I have seen various tutorials where the same thing is done and the stroke is only visible around the person. What am I doing wrong here?
Here are some pictures to illustrate
http://i22.photobucket.com/albums/b324/joe_stas/ScreenShot2013-03-03at12315...
http://i22.photobucket.com/albums/b324/joe_stas/ScreenShot2013-03-03at12311...
Paul Roper
Re: Keylight, masks and layer style question
on Mar 3, 2013 at 6:42:20 pm
You could pre-comp your footage (after you've applied the garbage matte and Keylight) - select 'move everything to the pre-comp' in the pre-comp options. THEN apply your stroke - that should do the trick.
- Paul
Vishesh Arora
on Mar 3, 2013 at 8:53:42 pm
Joe
You can create a Garbage Matte by using a Solid or a Shape Layer with Alpha Track Matte.
Check the Example:
5567_usingtrackmatteforgarbagemattefolder.zip
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
2011 3D Demo Reel:
Cassius Marques
on Mar 4, 2013 at 5:25:28 pm
you probably have a little alpha spill near that mask that is getting stroked by the style.
