3D Tracker Camera and Track Null object
igor carlier
on Mar 1, 2013 at 9:16:43 am
Hello all !
Im not sure i should be posting this here or in the basics .. anyway here it goes.
i have this shot of someone walking in a green screen , but the camera is following the person walking .
i want to eliminate the camera moving and have the person walking.
for that i tracked the background , a perfect track using 3D tracker Camera effect and i made a track null and a 3D tracker camera.
so now i want to have the source layer position linked to the tracker in a way that the camera movement is eliminated and we see the person changing position on screen instead of walking in the same position.
i tried parent the source layer with the null layer , with the 3D tracker camera layer , i tried linking with expression ... nothing worked
the result is the frame moves in the oposite direction that is needed to achieve what i want.
Roland R. Kahlenberg
Re: 3D Tracker Camera and Track Null object
on Mar 2, 2013 at 12:56:30 am
AE's 2D tracker set to track for stabilization should do the trick. Just track the person and all should be fine.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7)
