Text animation question
Anthony Marzilli
on Feb 19, 2013 at 3:22:39 pm
I love this guys work. Frasier Davidson. You can get what I am trying to achieve in the first 2 seconds of the video.... it does continue throughout the video if you want to watch.
His text rotates from the top down and swings a bit. I cant match how it looks!
What I have tried so far is enabling per 3d.... add a rotation animator... move the anchor point to the top... but I cant get the swing at the bottom... or have it fade in nicely the way he does. I can see to add turbulent displacement on the text to give it the jittery look.
I would appreciate any tips. I feel it has to do with two animators on the text but am having trouble figuring it out on my own. Im glad I have you guys here to fall back on. Thank you.
Dave LaRonde
Re: Text animation question
on Feb 19, 2013 at 4:23:28 pm
It appears the letters are being animated by an expression. You'll probably get a speedier reply to your query on the COW's AE Expressions forum.
Dave LaRonde
Former Sr. Promotion Producer
Ridley Walker
on Feb 19, 2013 at 4:27:50 pm
You might try a free preset from Mattrunks called AmorType.
http://www.mattrunks.com/en/tutorials/after-effects/amortype
Modify the first animator to 90 degrees X rotation and adjust the anchor point grouping alignment to -100%.
It looks like the Fraser Davidson example is not fading in but responding to a light in the scene.
Stef Prein
on Nov 24, 2013 at 9:54:28 am
"Modify the first animator to 90 degrees X rotation and adjust the anchor point grouping alignment to -100%."
This is exactly the answer I was looking for :) Thanks!
Stef Prein
director/motion designer at StudioFets.
Utrecht, The Netherlands
http://www.studiofets.com
Anthony Marzilli
on Feb 19, 2013 at 4:52:27 pm
Ridley.... that is perfect. I fudged with the parameters a bit and its exactly what I was looking for. Added an opacity parameter and it works great.
Dave. You were spot on. Its expressions..... man those guys are smart who write those things.
