Animation Stutters
Tommy Howard
Animation Stutters
on Feb 19, 2013 at 11:36:02 am
Hi guys,
I'm creating a HD animation to be presented on a 1920x1080 monitor. Part of the animation is simply a large image, that moves right to left (which loops as a screensaver). I Rendered out 50 fps because the animation is fairly slow and quite subtle, i thought this would help. But the movement of the image stutters slightly. Could this be to do with compression? Or would bumping the frame rate even higher help?
Thank you!
Tommy
Todd Kopriva
Re: Animation Stutters
on Feb 19, 2013 at 4:21:04 pm
See this:
http://kb2.adobe.com/community/publishing/908/cpsid_90843.html
After Effects team blog
