What if the source of a "Laser" is on its back?
Michele Poggi
on Feb 16, 2013 at 3:33:15 pm
I'm compositing a laser, this laser is being shot by a little robot that is giving the back to the camera.
I'm using VideoCopilot Optical Flares to do so, but I didn't find a way to solve my doubt and problem: when the laser should be hitting the wall in background, the flare reacts as if it was shot TOWARDS the camera.
5458_example.jpg.zip
I did mask the light to be behind the little robot but the effects it's clearly fake, is there any way to tell the Plugin to consider a point to be the source of the light that is pointing towards a given direction?
"Freelance Post-Producer"
Editor Video
Graphic Designer
Digital Compositor
Mail: snm.poggi@gmail.com
Mobile: +39 3349129191
Skype: sabakunomaiku
John Cuevas
Re: What if the source of a "Laser" is on its back?
on Feb 16, 2013 at 6:07:16 pm
Lens flares are basically reflected light hitting a camera lens, they always point towards the camera. No way to really turn them around. You will have to play with the options to make a flare that is more subtle to create the realism you are trying to achieve.
You might want to go with a smaller flare and use the beam effect for the actual laser.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Michele Poggi
on Feb 17, 2013 at 10:16:35 am
Thanks. ;)
Editor Video
Graphic Designer
Digital Compositor
