AFX CS6 Rendering 17000X15000
Gonçalo Perdigao
on Feb 13, 2013 at 10:15:15 pm
Hi there,
Im rendering a file that is 17000X15000 for print, and i'm using videocopilot lens flares and looks and trapcode plug ins.
I can work perfectly, but i can't render full quality, without AFX stoping working.
What is the best method to export just one Still image?
I have a PC with 30GB of memory, i7 with 12 threats and with 3 hard drives of 1T.
Thanks a lot
chris brett
Re: AFX CS6 Rendering 17000X15000
on Feb 14, 2013 at 8:57:29 am
--- easy one ...
1 ) scrub through timeline to select frame you want to print
2 ) slide the left hand ( yellow ) timeline selector up to the time line marker
3 ) slide the right hand selector right up to the time line marker ie whee the selected frame is -- this will give the frame you want with selection markers either side.
4 ) send to render queue
5 ) before printing make sure to deselect 'fields' and also consider whether motion blur needs to be 'on' or 'off'.
6 ) render out as usual
-------------- all the best ------chris --
Dave LaRonde
on Feb 15, 2013 at 3:53:59 am
You can use the Save Frame As command once the timeline cursor is on the desired frame.
You don't say how big the images sre in this very big comp. To be safe, I recommend that you turn multiprocessing OFF. So what if it takes 20 seconds per frame to render? It's just one frame, so you're done in 20 seconds.
Dave LaRonde
Former Sr. Promotion Producer
© 2018 All Rights Reserved
