Faster Rendering with both AE and PP CS6
Shane Sackett
on Feb 12, 2013 at 5:10:09 am
Hi everyone, I recently bought a computer to handle hd video editing and rendering better than my previous one. However, I notice that it still is not rendering at speeds I believe it should be capable of. Any tips to speed things up? The following are my computer specs:
h9-1420t Intel
• Windows 8 64
• 3rd Generation Intel(R) Core(TM) i7-3770 quad-core processor [3.4GHz, 8MB Shared Cache]
• 3GB Nvidia GeForce GT640 [DVI, HDMI and VGA via adapter]
• 16GB DDR3-1600MHz SDRAM [2 DIMMs]
• 2TB 7200RPM SATA RAID 5 (3 x 1TB HDD)
• No secondary hard drive
Here are some things I've tried for speeding this up:
-I keep my source footage on a second partition of my internal hard drive
-I have enabled multiprocessing in AE and toyed around with how much ram to allocate to each core
-I have tried using shift to deactivate the previews during rendering
-I've disabled the video thumbnail in the project media window
-I never run any other applications when rendering
-I have enabled GPU processing
Can anyone think of something else, or do you see any obvious mistakes I'm making??
Todd Kopriva
Re: Faster Rendering with both AE and PP CS6
on Feb 12, 2013 at 5:24:42 am
See this page for resources about making Adobe Premiere Pro and After Effects work faster: http://adobe.ly/eV2zE7
After Effects team blog
Rebecca Loche
on Feb 12, 2013 at 12:53:48 pm
hmmm
Marina Leontopoulos
on Feb 12, 2013 at 4:55:43 pm
At first you should take a look at the task manager. Is the CPU working at 100%? How much RAM (physical) is being used? Did you try out a SSD?
And also important: What components did your old computer have?
I moved from an Intel Q9550 with 8GB RAM to an Intel i7 3770K with 32GB RAM and it really made a huge difference...
Rina
Shane Sackett
on Feb 15, 2013 at 7:56:21 pm
The cpu is running at 100% but only about 15% of my ram is being used. My old computer was simply just a standard 2011 Macbook Pro i7 with 16gb of ram.
Todd Kopriva
on Feb 15, 2013 at 8:00:19 pm
Don't think that you need to see all of your RAM used all of the time. If the CPUs are at 100% and the RAM usage is at 15%, then this just happens to be a rendering task that is not RAM-intensive.
Follow the link that I provided earlier, and read/watch the resources that it points to. For example, this video introduces the idea of bottlenecks in processing, which is relevant to what I just said above:
http://www.video2brain.com/en/lessons/overview-of-data-flow-and-common-bott...
