Generated Stroke won't scale properly when camera is animated.
Spencer Morin
on Feb 12, 2013 at 1:40:15 am
Hey guys!
So I'm doing some vector based animation for a client and there's a circle logo that I'm recreating with a solid and the Generate: Stroke effect. The animation's all fine, but when I set a camera into the composition (or another one for that matter) when I try to start the camera close on the stroke and dolly out, or just scaling it, the stroke thins out and loses form.
It's a 1080comp, and I'm trying to keep it vectorized. Any suggestions? I've also tried the trapcode 3D Stroke filter and as lovely as it is it doesn't seem to be helping.
Vishesh Arora
Re: Generated Stroke won't scale properly when camera is animated.
on Feb 12, 2013 at 4:32:13 am
Spencer
This is because Continuously Rasterize is enabled. This will change the Render order of AE.
Walter has explained this before:
http://forums.creativecow.net/thread/2/1020260
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
2011 3D Demo Reel:
Dave LaRonde
on Feb 12, 2013 at 4:21:49 pm
There's something else to consider, too: you may be using a vector path, but you're using it in a bitmapped environment.
You assigned certain horizontal & vertical dimensions to your solid: it's bitmapped.
You're using the Stroke effect. It's definitely not a vector effect -- there aren't any in AE -- and so it's bitmapped.
If you get the camera close to this layer, you'll see aliasing, plain & simple. To avoid this, you have to make your layer a LOT bigger and scale it down. Then you stand a fighting change to avoid aliasing.
Dave LaRonde
Former Sr. Promotion Producer
Spencer Morin
on Feb 12, 2013 at 4:25:40 pm
I ended up using the 3D stroke from Trapcode which allowed me to create a stroke thick enough to fit on a 5k x 5k composition that I shrank down in the main comp. Worked like a dream.
The key is though that if you collapse said composition, it won't work. Every other comp except for that one is set to rasterize continuously.
Thanks for everyone's help!!!!
Vishesh Arora
on Feb 12, 2013 at 5:00:43 pm
Glad we could help
Vishesh Arora
Films Rajendra
Blog:
2011 3D Demo Reel:
