Edit target greyed out
matthew chapman
on Feb 8, 2013 at 10:16:14 pm
I did a motion track but forgot to put a Null object in as the target before the track. it was a long track (an hour or so) of position and rotation. Now when I add a null object, double click the later, and select the tracker the edit target is greyed out.
How do I get the edit target back for the tracking data? I searched the forums and followed instructions but nothing. Edit Target and APply are both greyed out.
thanks!
matt
Dave LaRonde
Re: Edit target greyed out
on Feb 8, 2013 at 10:41:34 pm
What WAS the target of the track?
You can use an expression pick-whip to use the position and rotation data from the track to use it with the null object.
Dave LaRonde
Former Sr. Promotion Producer
Todd Kopriva
on Feb 8, 2013 at 10:52:55 pm
Show us a screenshot of your Tracker panel. I'm guessing that you don't have a motion source or current track selected there.
After Effects team blog
Vishesh Arora
on Feb 9, 2013 at 9:06:49 am
matthew
Make sure your Tracker Type(Below Current Track Option) is what you have chosen before tracking. For example: Your Track Type is Transform when you started tracking. But by mistake you have changed it to RAW. In this case the Edit Target will grey out. It might be the problem.
Well a screenshot would solve the issue.
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
2011 3D Demo Reel:
